I have a Boss TU-2 that puts out a high pitched noise , not a buzz but more of a ring . It doesn't matter if it is off or on , plugged into bypass or output. That all makes me think it's the power section of the circuit , but not totally sure about that . Luckily the board has workable components on it that have part numbers you can see. I have rang out all the electrolytic caps and they come up good when in circuit. Looking for some ideas on how to proceed to troubleshoot this . Thanks.
BOSS TU-2 high pitch frequency noise
Do you get the noise when powered from a battery?
JPB beat me.
Does the tuner work fine apart from the noise?Last edited by Helmholtz; 04-16-2021, 04:18 PM.- Own Opinions Only -
Originally posted by miltown View PostYep that's why I tested them out.
What I mean is that low ESR doesn't necessarily means a good cap.
For proper function a cap needs to have sufficient capacitance, low ESR and low leakage.- Own Opinions Only -
I suggest that you removed R6 temporarily. If this stop the noise then you know that it's coming from the digital section. Assuming that it is, you need to figure how.
C5 is an obvious suspect. I know you checked it but sometimes it's easier to just to replace, or at least tack another in parallel. Other routes much be poor grounding of jack sockets to case.Experience is something you get, just after you really needed it.
Let me say that again as I don't have the ability to edit the auto corrections that generate nonsense.
C5 is an obvious suspect. I know you checked it but sometimes it's easier just to replace, or at least tack another in parallel. Other routes such bas poor grounding e.g. of jack sockets to case.Experience is something you get, just after you really needed it.
