Hi everyone,
I'm currently working on a 1978 V5 Electro-Harmonix Electric Mistress. Thanks to the help of this forum, I have already made a lot of process, sorting out a short at the power supply. I biased the trim pots using online instructions (http://www.metzgerralf.de/elekt/stom.../align.shtml#2) and an oscilloscope, and the pedal does work now.
Working on the circuit, I have found that the supply voltage is significantly higher than it should be, and I just can't figure out why. It should be regulated to 12-13.5V, but reads at nearly 16V.
I have attached the schematic, with my voltage measurements. The effect is powered using an 18V power supply (9V Truetone with voltage doubler).
So far I have tried:
Any help would be greatly appreciated!
- Replacing Zener with a new 1N5235B
- Checked all electrolytic capacitors, replaced the high ESR ones
- Replaced the 22k resistor in the voltage regulating circuit with 15k and 10k, but voltage didn't lower
- Checked the 10uf Tantalum cap parallel to the zener, it seems to measure fine
