Question on Dunlop Uni Vibe
  • Question on Dunlop Uni Vibe
    I've got this Uni Vibe UV-1 that I am fixing up and I got the basic effects functional, but notice that there is a noticeable loss of treble (and maybe some distortion) in chorus mode and what seems like a boost in treble in tremolo mode. I don't know if this is "normal" or something to be addressed when I open it back up to replace the pots.
    This schematic has been accurate for my use so far. https://www.freestompboxes.org/membe...0%282-3%29.pdf
    Glebert..... I just happen to have a Uni-Vibe in the house. But it is not something I am familiar with.
    In any event, when I listen to the dry signal and then compare it to the chorus, I do not hear any difference in the treble level. The same when I compare dry to vibrato. I also checked with the switch for the Vintage setting. I did not attach the controller pedal for this test.
    Hmmmm....
      It´s an OLD circuit, and I bet input and output impedances are "wrong" by modern standards, there´s a reason old pedals needed True bypass ... or else.
      I guess it´s affecting how your pickups sound, big time, and much worse, in an inconsistent way, as different pickups will react in a different way.
        I'm pretty sure the input and output buffering is the same for both tremolo and chorus mode, so I don't think it would be that.
          That's what I thought at first.
          But if you look carefully, the input buffer is bypassed by the switching Opto-Fet (U9) in effect mode.
          You might try to use a stand-alone buffer or buffered pedal before the Univibe.
            I do have a buffered pedal before the Univibe. I could see that bypassing might cause a difference between bypass and effects mode, but don't know how it would cause a difference between chorus mode and tremolo mode. I could live with the bump in treble in tremolo mode but the chorus mode sounds quite muffled.
              I have an original Univibe, one thing, when you activate it with the expression pedal , you lose some volume .
                AJ, that is really cool looking. I put my Univibe on the shelf after my last post in this thread, but was thinking recently I need to dig into that and figure it out. This is going to the be the "Summer of Finishing Projects, and Not Acquiring Any More."
                  ......This is going to the be the "Summer of Finishing Projects, and Not Acquiring Any More."
                  Ha! I wish I could count the number of times I've thought that. It never works out that way.
