Hello Folks.
I have this late 70's original Boss CE-1 that I have had lying about for years. I finally decided, because the chorus does sound amazing, that I would start using it.
I have tried this through two different amps and I am getting some strange behavior. In a 50watt plexi style amp it sounds like parasitic oscillation on the edge of the notes... this is the clip labeled "Amp-1". The "Amp-2" clip is a more modern-ish three stage + cathode follower amp - through this amp it just sounds like uncontrollable feedback.
I realize this is a long shot - but I have no idea where to even start troubleshooting. The chain is Strat (lace pickups) to Boss to amp... nothing else in between. I'm using a Reactive Load/IR system, so no chance of actual feedback. But even plugging the Boss in line, when plugging in to the output of the Boss (when the amp is on) just touching the tip of the cable to the jack, it goes nuts... again sounds like oscillation.
Any ideas are welcome - I figured it never hurts to ask, that maybe someone experienced this before...
I have attached two mp3's and an image - as far as I can tell, the unit is all original. Many thanks for even looking!
