Picked up an old MXR Blue Box, circa 1974 for cheap, untested. Haven't done anything with it yet, but the circuit board is just sitting loose in the enclosure, It seems like it should at least be cushioned and electrically insulated. Anyone know how to treat it? TIA.
Question on vintage MXR pedals
I found this gutshot of one.
It looks like they mounted all the parts flat to the board so that no leads would be able to touch the back cover. The jacks were plastic, so that took care of isolating the underside of the board. If you are worried about it, it wouldn't hurt to cut a sheet of plastic to put between board and cover like Roland does in their pedals."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by glebert View PostPicked up an old MXR Blue Box, circa 1974 for cheap, untested. Haven't done anything with it yet, but the circuit board is just sitting loose in the enclosure, It seems like it should at least be cushioned and electrically insulated. Anyone know how to treat it? TIA.
Jump in at 3:50 to catch the Blue Box in action:
- Likes 2
I always saved my old credit cards, and those fake credit cards they send out with offers to sign up fir one. They are handy sized hunks of plastic or at least thick card stock. Good for this sort of thing.Education is what you're left with after you have forgotten what you have learned.
- Likes 2
First time I came across a piece of nasty deteriorating black foam was an old vintage Color Sound wah pedal. Had to remove all that stuff out of the pedal. I used a piece of styrofoam and I wrapped it up in medical cloth tape. Main thing in these situations is to get creative with out spending any moneyWhen the going gets weird... The weird turn pro!
- Likes 1
Originally posted by J M Fahey View PostThat.
Probably the no clue earlier owner junked the "packing material" or "piece of foam" he found inside as some "useless junk"
I have a pet theory that MXR had a tendency to use tantalum caps because they could be easily laid on their side and were often smaller than electrolytics of the era of same capacitance value. Part of what made this necessary was MXR's use of larger pots than are presently used, and the somewhat larger footswitches. All of that left precious little room for the loaded board in the enclosure, so it had to be as low profile as possible. You will note that all the caps and transistors on that Blue Box board are laying flat.
There's a lot of different materials one can use for insulating the copper side of a board from shorting out against the enclosure cover. I like to buy this stuff at Michaels or similar hobby shops that goes by the name "fun foam". It kind of looks like felt and is the same size as a square of felt, but is non-conductive foam. Cardboard inserts work fine as well.
Originally posted by Mark Hammer View PostThere's a lot of different materials one can use for insulating the copper side of a board from shorting out against the enclosure cover.
I get ads in the mail made of a sheet of card stock laminated between plastic layers. None go to waste. Great surfaces to mix dabs of epoxy, or custom size insulators like what's needed here.
