Guys, I made my own looper/switcher that has only 3x 3PDT (loop) switches. One engages TUNER (and mutes the signal), middle one is just for the Fuzz, and third one controls rest of the effects. Simple.
High quality wires, switches, cabling.
[Photo below]
My signal goes through: BASS -> ZVEX SUPER HARD ON -> SWITCHER etc... -> AMP (yes, Zvex buffer is wired before everything)
Everything works. Switching, tuner bypass, etc.
However, even with everything switched off (or Zvex on, or zvex off) I get few decibels down from the signal comparing to straighforward connection BASS>AMP
It's not hi-end loss due to impedance cabling etc. Just volume down.
If 3PDT switches weren't wired right, there should be some problems like: ground loops, buzzing, no signal... but WEAKER signal? How's that possible?
I know that's hard to diagnose, but maybe some tips.. I just dont know where to do now. PS: It's PITA to disassemble everything, but I tripe checked my soldering and connections...
[Photo below]
