I obtained a partially working symetrix 501 compressor limiter. Specifically, the limiter side of the unit works, as does the makeup/output gain, but the compressor part of the unit does not work (i.e., attack, release, ratio knobs do nothing), though there are some working bits within that circuit (i.e., the threshold led triggers and its behavior is responsive to the threshold knob and incoming audio level, but only when the compressor "in" switch is engaged, which is how it should be). Because it was easy enough to do, I tried a replacement vca in the existing vca socket, to no avail.
I have attached the only schematic I could find for this model, though it details a later version than the one I have (mine is the alison/valley ppl vca, toggle switch version). I have also attached a picture of the "big black box" that appears in my version but not the schematic; the internet has suggested that "the rms detector" lies within.
I have confirmed that the voltage regulators are outputting the proper +/-15v (within 1% tolerance) and the resovoir filter capacitors have acceptably low ESR. I am hoping that all of the above information will provide you with enough detail to guide me as to what I should do next to evaluate and repair this unit. Thanks!
