Fulltone RTO wiring and tone control issue
  • Fulltone RTO wiring and tone control issue
    I got this Robin Trower OD. Previous owner removed the footswitch. I’m a little stumped as there are two leads left - one should be for the LED to the footswitch, the other I have no idea.
    the tone control also doesn’t work/has no effect. The volume and drive work. I’m trying to go through the circuit based on these layouts.
    http://2.bp.blogspot.com/-ws7iD3sZfJ...tone%2BRTO.png
    https://tagboardeffects.blogspot.com...drive.html?m=1
    Trace the wires and see what they connect to in the circuit. A schematic would be more helpful, if you can find one.
      I haven’t been able to find the schematic
        I think it's just a modified/tweaked TS9, so this should be close enough to figure out how it's configured even though some values may be different.
          Thanks for that schematic. I found the 220r that should be coming off the tone wiper was 4.7k. It’s weird if Fulltone did that stock. Could be the pedal was modded.
          Also found a wiring schem online via pictures of the OCD. It’s working but not sure if it’s working fully so I’ll have to snoop around.
          c2 was not included in the build.
            I meant C2 on the PCB was not included. Not from the schematic shown.
