EHX Tri Parallel mixer frozen issue
  • EHX Tri Parallel mixer frozen issue
    EHX Tri Parallel mixer frozen issue,
    This pedal works But you have to do a factory reset every time you power it on.
    Hold down ch1 - ch3 and connect up the power, as soon as you remove the power pack. and re connect it locked up/frozen. Seems to be a common problem
    I have contacted EHX about 7 days ago. No reply as of yet
    Does anyone know what is need to be done,
    No schematic online either
    Many thanks
    Mr A
    I have had a reply from ehx . The unit needs to a reprogram. Seems that it has to be done by them .
    If you are UK based contact ehx in Swansea Wales
