Hi guys!
I've built the awesome little Bazz Fuss. This version I found online and it sounds killer. The thing is I wanted to add a gain knob and, after investigating, I read that you should wire a 1k pot to the Emiter of the transistor (check the layout)
I've tried but it doesn't work out. When I turn the knob the signal just fades away and comes back. Should I try other pot values or is it because of the layout?
Thanks a lot!
Brian.
Thanks a lot!
Brian.
