Is it possible to add stereo inputs of such units as the Digitech RP-12 , RP-1 and Digitech 2112 effects units ?
Adding stereo inputs in older 1990's Digitech effects units .
Here are a few.
DigiTech RP1 Schematics.pdf
DigiTech RP1 Service Manual.pdf
DigiTech RP6 Schematics.pdf
DigiTech RP10 Schematics.pdf
DigiTech RP20 Schematics.pdf
DigiTech GSP2112, 2120 Schematics.pdf
- Likes 2
If you are asking if they can be turned into stereo units, the answer is no. The stereo output is created in the digital domain, but it is working from a mono signal.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
I'm looking for a repair tech for an RP1. Now when I plug it in all the lights light up, just lights. Read a forum a guy said to hold down the utility button then plug it in while still holding the utility button down press parameter up. It worked played fine. Went to use a few days later it did it again and the holding down buttons again isn't working. Anyone have this happen or know anything as to why? Maybe someone knows a repair guy. Thanks for taking the time to read this.
Originally posted by Mark Hammer View PostHi AJ,
Do you ask in order to have the units process in stereo, or simply to accept two inputs for whatever they do?
I want to add stereo inputs to my Digitech RP-12, RP-1 and to my 2112 SGS .
As near as I can tell, neither the RP-1, RP-12, or 2112 would accommodate stereo inputs. They may process the signal in a manner that provides a stereo output, but only as a result of processing a mono input and distributing two "versions" of the input signal to the output jack. True stereo processing would probably have required a more powerful DSP chip. One could certainly install a second input jack, but only to mix two different input signals down to a mono/composite signal for the unit to process, rather than independent signals that the unit would then treat independently.
- Likes 1
