Boy, I have sure learned a lot the past few months and still am a n00bie! I used to rip my CD's using EZ CD Creator, figuring that digital bits are digital bits... Not so!
It seems that at this point, a freeware program called EAC [Exact Audio Copy] has become the standard for ripping CD's, with more options than you can shake a stick at. I guess one goal is to transfer the files across the internet and then be able to create an exact copy of the original from the files (with the exact same gaps between the songs).
Stuff I've learned:
#1. SBE... "Silent But Ed-ly"? No, silly goose, "Sector Boundary Error". If you create your own WAV files and burn them to CD, you may have SBE problems which can add small gaps to the end of each track- mainly noticeable if the tracks are continuous, like a live show which is broken up into tracks. If each track is seperate and distinct then the added gap will probably not be noticeable.
More info on this- when burning an audio CD, the CD drive writes the data in full sectors, so if the file does not end on a sector boundary, the track will be padded with blank bits to fill out the final sector.
One handy tool to check and correct SBE problems is the freeware program "Trader's Little Helper". It offers two different options: fix mode and pad mode. In fix mode you input 2 or more files and it will move bits from one file to another, either forward or backward, so that all tracks will start on a sector boundary (the last track will be "padded" with extra blank bits). The other choice is the "pad" mode, which will look at each file individually and add blank bits at the beginning or end of each track so that there are no SBEs.
#2. FLAC is a handy format- [Free Lossless Audio Compression] Unlike most MP3 formats, there is no loss of information when the file is reduced to 40-60% of the original size of the WAV file. An added bonus is that you can add tags to your FLAC files, which will be displayed when you play them in WinAmp (or whatever). You can also add "replay gain" tags to the files, which will allow WinAmp to play all of the files at the same relative volume.
You can download FLAC plug-ins for programs like WinAmp and Cool Edit Pro so that the programs will recognize the FLAC format.
#3. You can configure EAC so that your CDs are ripped to FLAC files whenever you hit <Shift> F6. (If you hit <F6> by itself they are ripped to WAV files.) One problem I noticed- a few of my rips resulted in FLAC files with SBE flaws (supposedly not possible but it happened to me anyway). So I added "--sector-align" to the compression options for EAC, which seemed to work okay. HOWEVER... I found problems doing that with a live album- it would pad the end of each track so that there was a small gap between each track.
For that album I ended up ripping to WAV and then using TLH to use "fix" mode for SBEs, since the EAC/FLAC automatic combination evidently uses the "pad" mode.
... Well, that's enough for now- any posts on this subject would be appreciated since I am still trying to get all of this figured out and configured. (I just learned how to get EAC to run in "Secure Mode" last night- hooray!)
Steve Ahola
Stuff I've learned:
Steve Ahola
