Have just put together my first varitone switch with an inducter. When I access the 5 cap positions I get a 100% boost in volume (not distorted). The 1st position is normal, off circuit.
Is this down to the size of the transformer I'm using (we are limited as to suppliers in the UK so I am using mini trans)?
I am happy with the result but just want to know if this is normal. I have wired the caps together and they go to ground and the inducter is wired to the pole and then onto hot jack.
Thanks for any info...
