I just started having a problem with a MIJ (not for export) Epiphone LP Special....a very nice guitar.
The pickup selector switch seems to have gone buggy...when set to select the neck pickup, there's no volume unless the bridge pickup volume is turned up...if it's zero, there's NO sound from the neck pickup. The bridge setting and the combined setting both work as expected...it's only the neck setting that's screwy.
I've eyeballed the wiring in the main cavity and don't see anything strange, but haven't yet pulled the switch.
Is there a test I can do with my meter to see if indeed the switch is at fault?
Thanks in advance.
Thanks in advance.
