Scratchy tone knobs
  • Scratchy tone knobs
    Whenever I turn my tone knobs I get static unless i touch something metal on the guitar such as the strings, tuning knobs, etc.. Is this a grounding issue?
    Static cling
    Can you supply a name & model of the amp.
    Is this a winter, dry heat thing?
    It may be static.
      Ive plugged it up to multiple amps, ive used different cables too.
        If you get noise, hum, interference when you *grab* your knob, turn it or not, it's a grounding problem.
        Anyway, you should always be touching some metallic part of your guitar, to ground yourself to it.
        If a scratchy noise appears only while you turn the pot, you have a very dirty one.
