3 way Strat switch wiring with 2 pickups?
  • 3 way Strat switch wiring with 2 pickups?
    Well, I give up. I am trying to wire a guitar with two pickups: a Strat pickup and a P90, with a three way strat switch. I want it to work like a Gibson switch, that is, neck on one extreme, both pickups in the middle and the p90 on the other extreme. I can't seem to figure out how to get the middle position to work with both pickups without effecting the other positions.
    Anybody got a diagram/layout that can help me??
    thanks
    regis
    Stop by my web page!
    Tele Wiring.doc
    Note the attached wiring schematic for a Telecaster using a standard three-way switch. It's the same for a Strat or other guitars using two single coil pickups and a three-way switch.
    However, if you are using a toggle switch, as typcially used on a Gibson style guitar, that requires another drawing.
    I hope this helps.
      That is exactly what I needed, I should have thought to look at the tele schematic. thanks a lot!!!
      regis
