I'm working on a customers stock Gibson Firebird. The complaint is when not touching the strings or anything metal,when you touch a metal part or the strings to complete the ground there is slight pop. The control cavity has been shielded with copper foil as well as the cover. All the shielding is connected to ground. The rest of the cavities are not shielded,the long route that the switch wire runs under, the pickup cavities and the underside of the pickguard. I noticed that most of my guitars do the same thing. Some of my guitars are fully shielded and some are not. My non shielded guitars the pop is a little louder than my shielded guitars and his Firebird. Is this an impossible problem to solve? Aside from going 9V active pickups.
![Frown](https://music-electronics-forum.com/core/images/smilies/frown.png)
