Hola, I recently moved to a new house and my guitar makes much more noise now. The noise, the best I can describe, is a pulse of pinkish white noise at 7.83Hz with a 50% duty cycle. With the noise gate off and strings muted, if I rotate while holding the guitar in the playing position the noise is roughly -15dB to -70dB from 12 o'clock to 9 o'clock respectively. (9 o'clock being guitar perpendicular to the face of the amplifier)
The same noise can be found (on a different amp) when I lift the stylus of my turntable. I assume it is the resonant frequency of earth (shumann frequencies). Is there anything I can do cancel this noise or am I 'geographically screwed'?
Thanks?
Thanks?
