I am modding a buddy's Les Paul and considering the shape of the original wiring, decided to completely wipe and start anew implementing a new wiring scheme (new simply meaning not the stock wiring). It's a cheap chinese LP knockoff not an original, so it's not like it will lose value or anything. I am wiring it soldering all grounds to the bridge volume pot instead of using two conductor wires throughout the entire signal path as it was wired stock.
Both humbuckers are two conductor type wires. Bridge is Blue and Neck is Red. Rather than trying to painfully explain everything I've done so far using words I will post a picture.
From here I will need to solder a wire from the bridge volume pot center lug to one of the switch wing contacts and another from the neck pot output to the opposite switch contact. Then I will run a wire from the switch contact between those two wings to the jack's tip connection. A wire from the switch ground to the bridge pot ground. And finally a wire from the jack ground to bridge pot. If I am forgetting something or going about this incorrectly, please let me know. Any tips are welcomed as well.
