Vox Sidewinder IV Bass - H E L P ! !
    Originally posted by 52 Bill View Post
    If you think that the wiring diagram is something, take a look at the Assembly Drawing.
    As Mr Fahey said, WOW !!!!
    I wish i had an Ultrasonic, so my problems would be solved with those drawings ! Now, everything i need is the same... for the Sidewinder Bass ! ( ) I'm i asking to much ??
    Thank you very much anyway, Bill, this will sure be hepful for a lot of people here at the forum, and is the best i could get that far., you've got a new fan ! I'll let you (and all fellows that are following this issue) know about any progress.
    Fahey, muchas gracias a usted también !!
      Andre:
      Hopefully you will find the version for your bass. Check eBay here in the US as they turn up every once in a while.
      If you do a little comparison checking, the circuits for the Ultrasonic are not that different from the Sidewinder. There is a switch for each effect and there are controls for some of the effects. They will be wired the same on either guitar. Look at the circuits that you have and see what matches up. If you do post photos, amybe we all can help you figure it out.
      Best of luck. Keep us informed.
