floyd trem
  • floyd trem
    hey guys
    i just got an agile prs copy with a floyd rose floating trem.
    after seting it up for standard tuning using 2 springs, it played great.
    but when i bend the g string a whole step and catch the b string note, the b string is out of tune (1/2 step flat ). sooo i added 2 springs ( now it has 4 ) and re set it up again, it still moves the bridge and the b string is out of tune ( although not as far as before ). i also set the bridge at a slight angle down toward the back of the guitar. my guitar tech says this in normal for floating trems. seems wrong to me.
    thanks for any help you can give
    Clay
    That is normal for floating trems, but this will fix it.
    Tremsetter > Store > Hipshot Products
    It's bit tricky to set up, but works really well.
      thanks david
      yea, not a point and shoot install but looks kool.
      im going to give it a shot
      thanks again
      Clay
