The patient:
2009 Gibson SG Classic.
The issue:
Latent desire to switch out volume controls for 500k audio pots. However, this is one of the new circuit board control panel guitars from Gibson. Let's take a look:
The inside looks nice and neat. When the board is removed, the cavity is clean and plenty big for installing traditional pots and wires:
And now a view (or two) of the circuit board:
Out of curiosity, I measured the readings of the potentiometers in this guitar:
Bridge Volume: 305k
Bridge Tone: 458k
Neck Volume: 296k
Neck Tone: 412k
And yeah, the volume doesn't quite let the pickups bite as hard as my other P90 guitar. I especially noticed this the other night at a gig when I had to switch guitars due to a broken string... and noticed right away how the Gibson had a softer attack.
The guitar still sounds great, but I like that bark from the P90s and want to see if the change in pots will help bring that characteristic to the front.
So... do I really want to mess with this thing? There are five solder points on the circuit board for each pot. The ceramic capacitors (0.022) have two solder points and are quite easy to remove - much like working on a pedal.
I'm guessing (at this point) what I'll have to do is trim the round ends of the lugs on the pots so they are straight and then find out if Gibson simply uses a large goop of solder on the sides of the pots... or if there's something else making the connection between the pot and the board.
Has anyone worked on one of these recently?
The issue:
Bridge Volume: 305k
Bridge Tone: 458k
Neck Volume: 296k
Neck Tone: 412k
