This is a draft for a passive EQ scheme I put together. It's a bit of a hack yet it's the only way I've managed to implement the controls as functional. The main issue I've run when I try to remove the hack-ish second connetion to the jack is tone control behaviour becoming similar to a volume control killing signal at "0".
Implementing passive EQ scheme(including inductor) need help
This is a draft for a passive EQ scheme I put together. It's a bit of a hack yet it's the only way I've managed to implement the controls as functional. The main issue I've run when I try to remove the hack-ish second connetion to the jack is tone control behaviour becoming similar to a volume control killing signal at "0".Tags: None
This was posted over at TalkBass. You are shorting out the volume pot lugs, and from what you said over there the tone cap value is wrong, and it sounds like your tone cap is bad.
Are you expecting a different answer over here?
Just do what people are telling you to do at TalkBass and replace that tone cap.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Well you were getting answers from technically minded people (including me) at Talkbass. We are trying to help.
The Gibsons use a very different setup from the Q filter. Also, I think the Q filter has a cap in it. He makes a Q filter and an L filter. The L filter was just a coil.
You can wire the Q filter up to a tone pot and it will be just like the L6-S.
I had a Q filter in my Fender Mustang guitar back in the 80s and didn't really care for it. All it did was sort of smooth out the high end without rolling off the treble.
Your issue was the tone control working like a volume control however, which makes no sense if it's wired up the right way.
Does the tone control do that when the Q-Filter is out of the circuit?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostWell you were getting answers from technically minded people (including me) at Talkbass. We are trying to help.
Originally posted by RoadToNever View PostThe tone works as expected with the Q-filter out of the circuit
Maybe if you put the tone control on the input of the volume pot, and the Q-Filter on the output.
Or try wiring it up like an L6-S (also designed by Bill).It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
