'So, this sounds like an issue with saddle wear rather that the actual bridge sagging'
Well, it's a combination of the 2 that's causing a playability problem but honestly, those crummy bridges are sagging!
Saddle wear can be expected, but it doesn't seem sensible to replace saddles on a unit that's sagging; do I notch the outer saddles deeper to maintain the profile - how long till it gives way some more?
The 'Gibson ABR1' bridge seems far more sturdy that the 'Made In Germany' ones.
Rather than die cast iron, the material used is a non magnetic zinc type material; looking at it, you get the impression that it would give way under pressure over time.
