Ibanez Artcore AS 103 replacement bridge
  • Ibanez Artcore AS 103 replacement bridge
    I am looking for a replacement bridge for my Ibanez AS 103. I want something I can just switch out and not have to mod anything. I would like to just leave the bushings that the posts screw into but I don't know if that is possible.
    It looks like a regular Tune-o-matic. Just measure the distance from the two posts. One of the common bridges on the market should drop right in.
      What don't you like about the stock bridge? If it is missing you just need an import wide post Tune-o-matic style. If you want an upgrade, you would probably want the Tone Pros T3BT retrofit for metric:
