Originally posted by rjb
View Post
Advice about variable humbucker to single coil split?
Originally posted by Mark Hammer View PostI installed/modded the variable coil-cancelling tone control in conjunction with a compensated neck volume control..... Cancelling one of the neck coils to lower the inductance and raise the resonant frequency, in tandem with a bass-cutting volume pot, gives a nice range of sounds, while still letting full-volume/full-tone sounds provide as much balls as the stock instrument always had.
As you probably know, the original T-60 pickups were 3-wire, potted in epoxy to make the coil connection points inaccessible.
With both pickups in coil-cut mode, they form a "hum-enhancing" pair.
-rbDON'T FEED THE TROLLS!
Originally posted by Mark Hammer View PostSingle coils vary in the extent to which they pick up hum. I've wound single coils that pick up much less hum than commercial pickups. My point is that the "hum-enhancing" aspects may be more a function of the specific pickups than the circuit, per se.
Thanks,
