Originally posted by epis
View Post
1. "signal picking coil" (AKA "sensing coil") 7,000 turns of 42AWG wire; ~7.00K DCR, 2.0H inductance.
2. "noise picking coil" (not to be confused with the "nose picking coil" so I prefer to call it the "dummy coil"
The patent also shows that the nose, er, noise picking coil is shielded. One way to shield it would be to wrap the dummy coil with electrical tape and then wrap 1" width copper foil tape around that (be sure that it is in the desired shape when you do that.)
The patent mentions that heavier gauge wire could be used but it does not suggest the diameter, number of turns and DCR for the heavier wire. It also has a suggested schematic with two controls, one to reduce the amount of noise reduction and the other to brighten the sound a bit if desired.
The new paradigm of dummy coils introduced by the Chiliachki is not merely noise reduction for single coil pickups, but that the noise reduction is very transparent- it changes the sound of the pickup itself as little as possible.
Steve Ahola
P.S. Here is a link to the Chiliachki patent:
http://www.blueguitar.org/new/misc/p...chiliachki.pdf
