ok this is gonna seem like alot of questions all piled into one so if its unclear ill try and clear it all up upon request
basicly about 2 years ago i baught myself an emg 81 with the intention of putting it in one of my experiment guitars (not important but its been wired to death with all sorts of things) and back then i couldent get it to work one of the reasons at the time was it seemed like i was trying to mix my stock humbucker pickup with the emg and the stock pickup only had 2 wires to it
i did an experement once with the intention of running a third wire out of my pickup the result of which was one of the spare humbuckers out of said experiment guitar was coil tapped and still only had 2 wires so i gave up in the end
recently i have found the guitar and from what i can tell all of the wireing is more or less intact the only problem i am having is there is as yet no switch for the battery so i can cut the power down and it again recently came to my attention that the reason for the third wire is because it has a powered circuit inside the pickup which forgive my nooby-ness is completely new to me im used to having to cut out cavities in guitars to wire in a preamp and that one kinda took me by suprise
so as it stands now i wired the pickup up as best i could figure out from numerous wiring diagrams and the problem i seem to be having is with the 3 way toggle switch i have wired it forwards and backwards based on the pinout i was given but as yet i cant get just one of the pickups working on its own
so thats my first problem
my second problem is that it buzzes alot i suspect that is something to do with the wiring so im gonna have another crack at it and see if i get anywhere
basicly i just want some help in understanding where i am going wrong and essentially if its even feasible to wire in a stock pickup alongside an emg because looking at all these diagrams (and i have researched the hell out of it...it made a bit of difference clarity wise but im still pretty stuck) arent really helping me in any way
its a 2 humbucker 3 way lever switch 1 vol 1 tone
