Ground issues
  • Ground issues
    Hi all, this looks like a really good forum so I thought I would see if you guys have any knowledge about my issue.
    Basically, I'm using an ESP explorer with two humbuckers, the whole thing was rewired about a year ago without any issues. But now there's an awful buzzing sound that stops every time i place my hand or finger on either of the pots in the back of the guitar, or sometimes if I touch the metal part of the pickup switch around the front of the guitar. I'm guessing this is some kind of grounding issue. I have attached pictures of the pots and the wiring to see if that helps.. I have no idea what I can do!
    You will notice two sets of red and white wires twisted together but hanging loose out the back. I'm not sure if these should be connected? Thank you!
ID:	867193Click image for larger version
ID:	867194Click image for larger version
    I guess that the red/white wires are (unused)coil taps; best to insulate them, shrink wrap sleeving etc.
    I can't identify a bridge / tailpiece grounding wire; if that (and therefore the strings) aren't grounded then your symptoms will likely occur.
    Pete
      Pete
      Hi Pete,
      Thanks for getting back to me and for the help. Is it best I send it to a technician to carry this out? Or is there an easy way for me to do this at home?
        Have you got a test meter?
