Sanding inertia bar and tremolo plate
  • Sanding inertia bar and tremolo plate
    New here.
    Modding my Fender American Standard Strat.
    Well, my first mod is not a real electronic one but i have seen a topic about it in the past.
    My question:
    How to remove the paint from the inertia bar (like the Eric Johnson Strat) and make a 100% total/tight connection with the term plate.
    I have sanded the top of my Strats inertia bar but when i attach the trem-plate on it and hold it against the light, i can see some light coming through (a small gap). I suppose full contact will give better tone.
    It looks like the inertia bar is not totally flat nor is the tremplate.
    Is there an easy way to make a better contact.
    Jazzy
    Yes, keep sanding both surfaces until they're flat! The jargon term for it is "lapping".
    How to Lap a Heatsink Guide - Overclockers Club
    Then ponder the fact that the tone still has to come through 12 little grub screws.
      Thanks!
      Contains some valuable info i can use.
      I had it milled friday (?) by a professional so both are flat now but still a bit raw so i think i will wetsand them a little to improve the contact.
      Bought some sanding papers but took me half a day to find a shop that sold >600 grit (2500 now)
