More on ramping...
When you are lowering the action on a neck you will get to the point where the upper frets will "choke out" as you bend them. "Too far- need to go back a little!"
Instead of that why not lower the frets that are choking the strings? That way you can have low action for the first 12 frets or so and still be able to play on the upper frets. Of course you want to make sure that the ramping is even so the upper frets play well.
It's not something you want to do to all guitars or for all guitarists. Do it on a case by case basis. I will first level and crown the frets and see how it plays and responds to adjustments of bridge height and truss rod. If I am satisfied then I am done. If I think it needs a little ramping I will do it and check it out after recrowning the frets.
Did I mention the Fret Rocker? That has been the most important tool in looking for high frets causing buzzing and choking...
Here is where I learned about ramping...
This is the 9 inch Beam Fret Ramping Sander. The beam was cut to to length particularly to ramp the frets from the 13th fret. It is not long enough for properly leveling your fret height. Solid constructed thick 100% aluminum frame. High gloss Enamel baked finish. This Beam Sander comes from the Tommy Star Beam Collection of 3 Beam sanders available on E bay . Sizes come 20 14 and 9 in. Comes with 3 cuts of paper. This paper can be purchased by 50 ft rolls at your local lumber and tool stores. The price is about $7.50. One piece of paper will do 3 jobs. cost about 17 cents.
Sanding down the fall off
Step 1 Remove the strings
Step 2 Carefully adjusting the neck to perfectly straight. Using a (quality) straight edge. Take your time this is a critical step
Step 3 Color all your frets on the top with permanent black or blue marker from the 13th fret and tape over 14 th fret
Step 4 Make a close inspection of all the frets to see if they are flat to the fret board
If any frets are lifted correct the issue
Step 5 Begin sanding the tops . Do not apply pressure let it glide freely
the tool will do the work. For most drop off I have found very little needs to be removed.
A close eye with magnification is needed so you won't sand lower than you need.
Step 6 Look for the top of the fret to come through. When all are showing you should have a shiney line that is slightly getting wider as you get closer to the sound hole or pickups.
Step 7 Take your fret rocker and go around the frets as a second check.
Step 8 Dress the tops of the frets back to there normal shape.
Luthiers Beam Sander for Fret Leveling and Neck Ramping | eBay
