I use both the tone and volume pots on my guitars alot but never really thought about it. What is the difference between audio and linear pots?
Audio or linear pots. What makes them different?
The taper of the resistance change vs. shaft rotation is different and there are more variations than the two (Liner & Audio taper).
Check out the article "The Secret Life of Pots" at The Secret Life of Pots
The various pot tapers and more are explained very well.
Originally posted by The Dude View PostYes. An audio taper pot will give you a more gradual volume change as you sweep the pot."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostAnd to add... The specific audio taper can also be important. There's a wide range of tapers available ranging from 10%ish to about 30%ish at 50% pot rotation. IMHE the more gain you prefer the lower the number you'll want. Bournes makes a good 10% taper pot and I've been using them happily.If it still won't get loud enough, it's probably broken. - Steve Conner
All of this essentially boils down to the way your senses work. For all senses, small differences in intensity are detectable at the low end, but as the stimulus gets more intense - whether visual, auditory, taste, or whatever - it takes bigger and bigger changes to make a "jnd" (just noticeable difference). So the taper on audio pots is intended to produce small changes with rotation at the low end, and bigger changes at the high end, for roughly the same number of degrees of rotation.
Linear-taper pots are useful when the "middle" of something is desirable to know. For example, many cut/boost or mix/balance controls use linear pots since the middle position of that pot will have equal resistances on each "side" of the midpoint.
Originally posted by eschertron View PostThe audio/log pots that I've tested (Alpha, CTS, PEC, and Bournes) all seem to be 10% taper. I'd like to get a hold of some 30% taper pots, but haven't seen them specifically advertised. Do you have a line on some different tapers?
edit: Here's a link: Fender 1 Meg Solid Shaft J Panel Mount Pot For Amplifiers
My two cents: I've found that for pots where you're increasing from zero (an amp's volume control for example) that audio taper provides the smoothest transition from quiet to loud. Conversely when you're decreasing from 100% (guitar's volume control or volume pedal) linear provides a smoother transition from loud to quiet.
Gibson typically uses linear taper volume pots and audio taper tone pots, which I've found more useful than Fender's use of audio taper volume pots and linear taper tone pots. In the guitar though it's personal preference of the user. Where do you want most of the sweep to be? With an audio taper volume pot, to me it feels like nothing happens between 10-7 and then there's a sudden drop between 5-0, while with a linear taper volume pot there's a fast drop from 10-5, but a slow drop below that.
I actually have a reverse audio taper in my volume pedal which I've found ideal for swells.
Ok... I knew something was up when eschertron posted that Alpha's audio pots are all 10% taper so I went to my stash and took some measurements. My memory was that the standard Alpha pots were as follows:
1MA =10%
500kA=15%
250kA=25%
I only had some 1MA and two 500kA pots to test (no 250kA in stock). One of the 500kA pots is old stock and one more recently purchased. The 1MA measured 10%, as expected. The old 500kA pot measured 15% and the new one measured 10%. Aha! Indeed Alpha must have changed their MO because when eschertron asked about a source for 30% pots I almost suggested that the Alpha 250kA pot wasn't a 10%, but rather a 25%. Glad I checked. I expect if I had a new Alpha 250kA to measure it would probably be 10%. I'd have to open one of my amps to measure an old 250kA. Not going there. But trust me. They use to be 25%."Take two placebos, works twice as well." Enzo
Originally posted by potatofarmer View Postwhy??
Originally posted by potatofarmer View Postedit: Here's a link: Fender 1 Meg Solid Shaft J Panel Mount Pot For Amplifiers
Originally posted by potatofarmer View PostMy two cents: I've found that for pots where you're increasing from zero (an amp's volume control for example) that audio taper provides the smoothest transition from quiet to loud. Conversely when you're decreasing from 100% (guitar's volume control or volume pedal) linear provides a smoother transition from loud to quiet.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by Chuck H View PostOk... I knew something was up when eschertron posted that Alpha's audio pots are all 10% taper...If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View PostWell, actually I posted that they seem to be 10%. My testing routine generally involves trying to get the wiper to the halfway point, often with no knob or indicator to use as reference. So a 15% taper is certainly within my testing margin of error! I will have to go back now and be a bit more rigorous. If have some 25% pots, I'll mark them as such for my tinkering"Take two placebos, works twice as well." Enzo
