P90s are single coils, but they are not like a Tele or a Strat pickup. They have a much larger and resistive coil. (They were one of Gibsons first pickups and also why they are so large) The thing with a lot of modern HB pickups is that they are overwound for higher output (hot pickups). It tends to make them darker.
Wiring ANY pickup direct simply removes all other variables so you can start from a real base line situation. It takes 2 minutes. If you like the way it sounds direct, then I would suggest 500k or even 1meg pots.
