Thanks Chuck! This one is pretty stripped down, even for me. Altogether it's been a very successful experiment. I couldn't be more pleased with the results. I started this one as a learning tool, so I didn't invest more cash into it than needed. I'm such a minimalist by nature that I absolutely love the simplicity of it though. It just proves to me again that a guitar is much more than the sum of it's parts. This is going to change my outlook on building in the future.
Multi-Scale Guitars
Hell, yeah! That turned out great! I'm particularly impressed at how the multi-scale just sort of disappears in the general cool retro vibe. People are going to look at it, and say, "That's a sweet little red rocker," and then later notice "... oh, look at that, it has those funny frets." Some instruments, like mine, are designed around drawing attention to the asymmetry of the different scales, but it's important to the proliferation of the multi-scale movement (OK, that's a little dramatic) that people see that it can fit into classic designs and they don't have to subscribe to a look that is outside their comfort zone.
That's a fairly silly analysis. I should just say, you done good, and leave it at that!
Originally posted by Jason Rodgers View PostHell, yeah! That turned out great! I'm particularly impressed at how the multi-scale just sort of disappears in the general cool retro vibe. People are going to look at it, and say, "That's a sweet little red rocker," and then later notice "... oh, look at that, it has those funny frets." Some instruments, like mine, are designed around drawing attention to the asymmetry of the different scales, but it's important to the proliferation of the multi-scale movement (OK, that's a little dramatic) that people see that it can fit into classic designs and they don't have to subscribe to a look that is outside their comfort zone.
Originally posted by The Dude View PostI'm not a luthier or a pickup maker, so I've nothing to add to the thread but have been following. Great work John!
A bit of speculative theory, perhaps... It seems, to me, that with the scale differential skewed at both ends of the fingerboard (which also looks cool) that there is a real playing benefit too. Not just a tonal difference. Follow me on this... Playing technique varies, of coarse, but speaking for myself, I mostly bend lower strings in the lower registers by pulling them down and higher strings in the upper registers by pushing them up. So, using my own playing model, the way the frets are skewed will minimize the necessary string travel on bends. Reducing both distance and pressure and therefor, theoretically, make bending strings easier. Since I've never played a multi scale guitar I'd be interested in reports about this if you ever show this guitar off to players."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostA bit of speculative theory, perhaps... It seems, to me, that with the scale differential skewed at both ends of the fingerboard (which also looks cool) that there is a real playing benefit too. Not just a tonal difference. Follow me on this... Playing technique varies, of coarse, but speaking for myself, I mostly bend lower strings in the lower registers by pulling them down and higher strings in the upper registers by pushing them up. So, using my own playing model, the way the frets are skewed will minimize the necessary string travel on bends. Reducing both distance and pressure and therefor, theoretically, make bending strings easier. Since I've never played a multi scale guitar I'd be interested in reports about this if you ever show this guitar off to players.
Is that a "hollow" I see at the control cavity? So will this be a semi hollow seven string with an extended bass scale? A very different concept from how seven strings are usually seen (shred/metal). Seems like a great idea."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIs that a "hollow" I see at the control cavity? So will this be a semi hollow seven string with an extended bass scale? A very different concept from how seven strings are usually seen (shred/metal). Seems like a great idea.
Definitely going to be a players guitar with a lot of very musical possibilities."Take two placebos, works twice as well." Enzo
I'm "subscribed" to the thread. So I was able to see that a post had been added. I knew it was almost certainly just kudos for the pretty guitar but I clicked to see anyway. Just so I could look at it again"Take two placebos, works twice as well." Enzo
By the way, how are you liking that 7th string? When I strung up my 7-string, it wasn't the 1.5" difference in scales that made me fumble-fingered, it was my right hand getting lost. The muscle memory for picking across strings has to adjust, but now I can go back and forth between 6s and 7s. That's good, because my next will be an 8-string!
