Originally posted by TomCarlos
View Post
Taylor Expression System ES II Fused String Ground
Enjoy. Every. Sandwich.
Just a final footnote to this thread. I recently bought a new Taylor 712CE that has the Expression System 2 (ES II). First thing I did? Remove the end piece to deal with the fuse. And what do I find? Taylor no longer uses a fuse on the ground lead !! So, I guess their initial argument for safety became more of a headache than they wanted to deal with - so no more fuse.
For those coming along and reading this thread, just make sure your PA gear is properly grounded. If you want absolute isolation, get yourself wireless mics and wireless instrument systems.
Thanks again for the responses above.
Tom
My guess is that the fuse wasn't viewed as kosher by NEC. Code requires that every piece of metal on an electrical appliance that plugs into something that eventually plugs into the wall needs to be grounded. Period. (Unless it's double insulated). If there's a fuse and the fuse blows then there's no ground and that's a no-go. It's all about liability and liability will go to the first thing in the source where someone fucked up, i.e. the panel installation or the outlet. NEC assumes that every commercial outlet and panel is being installed by a licensed, bonded electrician. If a club owner fucks up the owner is liable 100% but if the guitar has a fuse then maybe a good lawyer can point to that and say "hey the guitar manufacturer shares some blame" even though that's a ridiculous assertion.
Every touring musician should carry an outlet ground tester and a power strip with a GFI or GFCI (ground fault interrupter).
Originally posted by MarkusBass View PostI was lately fixing one of Taylor's guitars. The fuse was open. So it looks like it is useful sometimes. I've got great support from the guitar maker. They really care for their customers. No need to mention that the guitar sounded great.
Mark
