Originally posted by rjb
View Post
Neck shaving
Originally posted by Richard View PostI think I watched that video. She used a file, if I recall correctly at least in the later stages.
Originally posted by Richard View PostI don't think I'd whip out a belt sander as was mentioned here,
The mando guy actually used the belt sander to make the neck narrower.
I would have guessed that would destroy either the frets or the belt. Hey, what do I know?
Originally posted by Richard View PostI might get a coarse belt, cut it and have at it shoeshine style.
-rbDON'T FEED THE TROLLS!
I shape my necks with a spoke shave. You can take long pulls that cut a fairly uniform facet, and it's easy to focus on those shoulders to bring the profile in. I follow up with 150 grit on a hard block, then on a foam block. Make yourself some simple profile gauges from card stock to check progress. I always feel like I'm taking off a ton of material, then check with the gauge to find that I have a long way to go.
Originally posted by Chuck H View PostYou could always drill a miniature hole just off center of the fingerboard and probe it with a needle or a wire. Such a small hole could be patched to pretty much invisible. I once drilled brass dowel to make my own carburetor accelerator pump jets. I don't remember the actual size of the bit I used, but it was tiny.
Steve AholaThe Blue Guitar
www.blueguitar.org
Some recordings:
Originally posted by Steve A. View PostRiffing off your suggestion I'd heard of pulling a fret or two *very carefully* so that they could be hammered back in. (This was to remove a glued-in neck on a guitar from the 70's by drilling small holes in the fret slot and injecting boiling hot water over a period of a week.)
Steve Ahola
It's already close. A scraper should be all you need. It's amazing how much of a difference 1/16" makes.
Whatever method you decide to use, get familiar with the tool by practicing on some scrap. It's pretty hard to 'un-shave'
