Friends...
I am customizing a Cort Acoustic Electric Guitar by replacing the existing preamp system with a custom system. To do this, I need to find some 50K ohms pots that look like the attached doc. I've been looking all day and do not see anything that would fit. Yes, I have looked at Mouser and other parts supply shops.
As you can see, the overall length of the shaft is approx 18mm. Most of that is the threaded portion that goes through the body sound board. The knurled portion of the shaft is approx 7mm. The threaded portion is approx 11mm. The base diameter is 15mm (but I can go with something larger).
Most of the pots I have found (mini style) are too short. Has anyone see anything like the pot shown here?
Thanks,
Tom
Thanks,
Tom
