Originally posted by bob p
View Post
Chinese Gibson clone neck..... makes you wonder?
I'm going to have to plane about a 1/4" or so off the back of the neck tenon I believe. It already fits together fine in the pocket.... just the fretboard is setting a bit to high. Also worried about routing it for the neck pickup. I don't know where and how the truss is anchored. Will clamp and set it up with monofilament fishing line before I glue it. Deciding if I will shave the heal too.
Fishing line -- great idea. I've been using colored thread."Stand back, I'm holding a calculator." - chinrest
Hide glue. Any glue made of polyvinyl acetate will creep and shift under tension. Bad for a guitar neck. With hide glue you can get it apart again when you need to reset it. Can't do that with PVA or epoxy.
https://www.google.com/search?q=pva+glue+creep"Stand back, I'm holding a calculator." - chinrest
Originally posted by bob p View PostWith hide glue you can get it apart again when you need to reset it. Can't do that with PVA or epoxy.
I remember Ben Crowe of Crimson Guitars was a big advocate of PVA for years until one day he pulled a fingerboard right off a neck with a little tug, he was quite embarrassed and was gratious enough to show his blunder in a Youtube video. Since then he has stopped using PVA and is back to using more traditional adhesives.Last edited by Sowhat; 08-21-2017, 05:35 PM.... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
Originally posted by bob p View PostAny glue made of polyvinyl acetate will creep and shift under tension.
That joint continued to creep slowly for the next twenty-odd years, particularly in warm weather. I could move it back with slow pressure (weights, etc), but it would just start to creep out of place again as soon as I took the corrective pressure off.
-Gnobuddy
Dawg -- if you don't want to deal with hide glue, then the Fender bolt-on method is an option."Stand back, I'm holding a calculator." - chinrest
So I’m finally getting back to my projects after some heath issues. My biggest problem now is having to remove a 1/4” off the bottom of the neck tenon where it faces the bottom of the neck pocket. It has to be accurate and level. I did have a buddy with a power planer but he’s evaporated. What’s the best way to do it by hand? A big sanding block and a lot of patience?
Originally posted by olddawg View PostWhat’s the best way to do it by hand? A big sanding block and a lot of patience?
Is it possible to saw a number of closely spaced parallel cuts, say 3/16" deep, into the bottom of the tenon, chisel off the wood, and then just sand down the remaining 1/16" till it's flat and level? I've used this technique a few times, but never on a guitar neck.
Even better, any chance of getting access to an end-mill? It will then be a matter of finding a way to clamp the neck, bottom-up, with the underside of the tenon level, and milling off that 1/4" in several small passes.
-Gnobuddy
Originally posted by olddawg View PostSo I’m finally getting back to my projects after some heath issues. My biggest problem now is having to remove a 1/4” off the bottom of the neck tenon where it faces the bottom of the neck pocket. It has to be accurate and level. I did have a buddy with a power planer but he’s evaporated. What’s the best way to do it by hand? A big sanding block and a lot of patience?
Originally posted by bob p View PostI bought a strat and it wasn't quite as good. The bridge was located too far off to the treble side, such that the high E is too close to the edge of the fretboard and the low E is too far away. I've removed the bridge and pulled the LP-type bushings for the tremolo studs out of the guitar. I'm going to plug the two holes for the bridge bushings and drill two new holes to relocate the bridge 2mm toward the bass side. that should take care of the alignment problem."Take two placebos, works twice as well." Enzo
Originally posted by olddawg View PostI may have to find someone with a table saw (as mentioned earlier) and make a hundred passes.
Also, this might be useful (though I'm not sure I would be brave enough to try it on a guitar tenon): Cut Big-Time Joints with a Small-Time Saw
-Gnobuddy
