I'm having a minor hum problem after adding the Fender 4-way Tele switch to my new G&L ASAT Classic (basic Telecaster type guitar). The 4-way switch adds a series connection to the standard Tele wiring. I followed the official Fender instructions that came with the switch, which I've attached below.
![Click image for larger version
The new selector switch works fine, but I'm having a minor noise problem. If I don't have my hands on the guitar, and I touch the metal control plate or the stalk of the selector switch, I get hum. (No noise if I touch the metal knobs on the pots, which are floating on plastic shafts.) If I keep my hand on the metal control plate and touch the strings then the buzz stops. The buzz appears to happen in all switch positions; in other words it's not coming from an un-shielded neck pickup, whose cover's ground connection hast to be cut and re-established with a new wire with this mod. I can touch the neck pickup cover without any buzzing.
The wiring that adds the 4th switch setting requires that the neck pickup cover be disconnected from the pickup's ground wire, so that a new dedicated ground wire can be added that connects only the neck pickup cover and not to the pickup itself. This provides a dedicated path from the pickup cover to pot case star ground. The original ground wire for the neck pickup then goes to the switch as shown in the wiring diagram. In this model the neck and bridge pickups' hot leads are switched for normal parallel pickup selection, and the neck pickup's ground lead is switched to provide series wiring.
The guitar as it came from the factory does not have a ground wire soldered directly to the metal control cover plate and it does not hum like this. (I think most Tele's don't have a solder point on the control plate.) Before the mod my guitar didn't have a hum/buzz problem when I touched the cover plate, presumably because the original Cortec pickup switch that I removed had a metal box body with a ground post on it that connected directly to the pot star ground point.
Interestingly, the new Fender 4-way switch does not have a ground terminal on it's frame, so the grounding of the new switch has to be made through the screws, to the cover plate, and then via the bodies of the pots to the pot start ground. The screws and nuts are all nice and tight.
Is this a common problem with the Fender 4-way wiring? It doesn't have a dedicated ground connection from the frame of the switch to the pot star ground. I think that if this were a common problem I would have heard about it, but I'm not seeing the problem being reported online.
As to why I'm getting buzz when touch the control cover plate -- it would seem that the plate doesn't seem to be all that well grounded with the new wiring paradigm -- apparently my body is acting like an antenna when I touch only the cover plate. If I keep my right hand in contact with the cover plate I'll get buzz, but I get grounded out and the buzz goes away as soon as I touch the strings with my other hand because the bridge is well grounded with it's own ground wire.
Right now I'm liking the series connection that the mod offers, but I'm definitely not liking the buzz that happens if I touch the cover plate without keeping my other hand on the strings. Has anyone else experienced this problem? I have to admit, I'm not at all happy about what seems to be the only solution -- grinding down on the cover plate to rough it up enough to add a ground wire going to the pot star ground. I would have thought the connection of the cover plate through the pot bodies would have been good enough.
Am I missing something?
