I just wired up a calibrated set of strat pickups and running into a problem that's got me stumped. Hoping someone else might shed some light. The pickups all work great in the 1,2,3 and 5 position. For some reason the d string (and only the d string) on my guitar is really weak when I go to the 4 (neck and middle). The d string output is fine with neck or middle alone though. Help!!!
strat pickups
Some more info needed.
Is the Set RWRP?
Check the polarity of the D string magnets in the Neck and middle?
If It is RWRP set, and the polarity is wrong on the neck D magnet, that may be what's wrong with it.
If that is what it is, you may need to reverse mgnetize the neck D magnet.
Just a guess.
Anyone else got any ideas?
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Thanks for the tip. It does seem like a d pole somehow changed polarity. The middle is RWRP. In general the pickups are reading south up on the neck and bridge and north up middle. I can't imagine how one pole could change but sounds right. I will check it out. Unfortunately my compass won't isolate over one pole and I don't have one of those stew mac specials that will go over the top of one pole but I will figure it out.
My guess would be when it was assembled the mgnets were already charged, and one got turned over.
With the pickup out, I would just recharge all poles in the neck pickup the same, and go from there.
GL,
Terry
Originally posted by Rock Bottom View PostUnfortunately my compass won't isolate over one pole and I don't have one of those stew mac specials that will go over the top of one pole
