Tung oil, Tru oil, Danish oil, Teak oil, etc. all have an amber tint to them. They also amber more with a little age. I wouldn't worry about the color.
Use any oil finish you like. In my experience there are none that would be bad for the job. I did a few pool cue shafts with Daly's Teak oil. I liked it because it dries faster than the tung oil products and it feels just as smooth and tack free as my tung oil guitar necks.
Four coats. Just soak it in, let it sit for twenty minutes and wipe it dry. Repeat four times on successive days in dry weather. If it's humid wait two days between applications. Don't rush it. For extra good results apply the product again right after the first coat soaks in and areas look dry (which it will) and then wipe after twenty minutes. But do this for the first coat only. Then do a light sand with 320 grit paper before the final coat.
Some guys like to do more coats until they get a lot of surface build and sheen, but this is not necessary for protection, takes a lot longer to dry, stays softer longer and the extra surface build negates the smooth, non stick, raw wood feel. It will eventually buff to a sheen from playing even with four coats, but it will never feel sticky on sweaty hands like a shiny finish can.
DO NOT WAX!!! Just oil. Waxing over the top of the oil finish too soon (like, within a month) can greatly extend the full cure time. Also, wax can slightly emulsify with salty sweat and body oils making the neck look grimy and feel gummy unless you continue a regime of cleaning and waxing forever after. I have one neck that's probably twenty five years with tung oil. Never refinished, never waxed and has buffed to nice semi gloss finish. Feels smooth as silk.
