I looked them up and they're made for PRS guitars as well as being available from aftermarket vendors. Just *oogle stratocaster tremolo screws grooved.
One thing that I especially like about the grooved screws that the standard screws won't do is allow for a raised parallel bridge plane. That means you can pull up or push down and the physics regarding string bends and detuning that Helmholtz discussed could still be idealized (not to mention that it looks better). If you need a lot of pull travel for your tricks and techniques you can always add a tiny tilt to the neck so that the screws could be raised a little without detriment to action height
The image on the left is how I did my screws. On the right is just a sketch of what I'm talking about in this post. Same pull travel as the tilted bridge with the stock screws, but now you can have the bridge parallel to the body.
Also demonstrated would be Dulles 30° tilt. As you can see, it's pretty extreme and I think Dulles may even reassess his commentary and agree that this isn't what he's doing with his guitar. Especially since it seems physically impossible to keep the bridge saddles on the bridge or add enough tilt to the neck and adjust the rest of the guitar at this point without excessive action height and pickups well below the strings.
