At what volume level? Acoustic energy depends on the physical movement of air.
As the bridges didn't show any signs of vibration up to 700Hz, no significant vibration is transferred to the guitar body via the bridge. In other words, the direct vibrational coupling between strings and body of the analyzed solid body guitars tends to zero (acoustic guitars are a completely different matter). And this is good as otherwise sustain would strongly suffer. Vibrational energy that is once transferred from the strings to any other part of guitar practically has no chance to re-enter the string and thus is lacking from the electric signal.
It could be shown that vibrational energy is indeed transferred from the strings to the neck especially at a number of neck resonances. From this it seems that the sustain is primarily influenced via the neck. As the guitar body is rigidly coupled to the neck, it becomes part of the vibrational modes of the neck, thus considerably influencing neck resonances and damping. So the body's stiffness, shape (including type of neck joint) and mass matter.
It also could be shown that the guitar players hands (and belly) influence neck resonances and damping/sustain.
As there is little chance to excite string vibrations via body > bridge > string, acoustic feedback most probably works by the moving air "shaking" the neck or directly exciting the string.
Appearance aside, would you really consider subbing your strat body for one made of rubber or steel to have insignificant tonal affects?
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
I'd be interested in seeing it if you have a link.
You might inquire at https://www.gitec-forum-eng.de/landi...-news/contact/ to see if Zollner's book "Physics of the Electric Guitar" is available in English meanwhile, or ask them specific questions.
