I've got 4 push-pull pots on the way and I made up the following diagram. I'm no expert so if you guys could tell if it makes any sense.
Bridge Volume - Gets the two coils in the bridge pup in either parallel or series
Neck Volume - Gets the two coils in the neck pup in either parallel or series
Bridge Tone - Splits the coils (single coil) in either bridge or neck or both
Neck Tone - Puts the bridge pup out of phase
I figure the different configurations will be:
Bridge series
Bridge series + Neck series
Bridge series + Neck parallel
Bridge parallel
Bridge parallel + Neck series
Bridge parallel + Neck parallel
Bridge single
Bridge single + Neck single
Neck single
+ all the out of phase options
Bridge series
Bridge parallel
Bridge single
Neck single
