Originally posted by Chevy
View Post
Of course I'm used to hearing an amp's influence on a pickup's/guitar's tone, and that is the only true and useful reference I have;
I recently wound a high output humbucker for my Charvel, and even though it sounded great distorted, it was too dark sounding clean. So I knew I would have issues with it when I wanted a bright bridge humbucker tone.
It shouldn't matter if the amp is tube or solid state either, you can still hear the tone of the guitar. There's a lot of great recordings done on SS gear. Listen to all that ZZ Top stuff from the 80's... it was all done with a Scholz Rockman! All those Brain May solos are done on a SS hi-fi amp... the Deacy Amp. My buddy has one of the Vox versions of the Deacy, and it sounds exactly like May when I played a Les Paul with the neck pickup's tone all the way off through the thing.
I do own a big Mesa tube bass amp, but I never use it anymore. I only ever play guitar in the studio, so I haven't owned an amp in a long time (the little Crate amp I have notwithstanding)
You seemed to be tracking with me earlier and then even produced a guitar/pickup that has some of that "hollowness" quality to it...... which is awesome..... but now are you telling me that every guitar you play has that characteristic because it's in your hands?
But if you play a lot of guitars, and you can't get that tone from them, something's not right. I'll be the first to say pickups make a big difference in tone, but I've gotten that tone out of a bunch of different guitar/pickup combinations. I was going to put a humbucker at the neck on my Charvel, but I liked the tone from the DiMarzio Solo Pro in a customer's guitar so much, I decided to stick a single coil at the neck, and really, I pulled one out of a junk box. I made a number of changes to it, but I'm sure it sounded pretty much the same before hand.
I dont' disagree that guitarists have a certain sound unique to themselves, ... All I'm trying to say is that the guitars sound different, too. You evidently have just proved that point by demonstrating this on the mutt Charvel of yours.
Chevy.
Chevy.
And the fact that I'm playing a mutt... don't get sucked into the whole Fender makes great guitars thing. They did once, and now they are fairly pedestrian. Some are good, some not so good. Sometimes the tone will come from the most unlikely of places. I had a cheap plywood body Hondo II P bass copy once that someone gave me. I changed the hardware and pickups, and it was a great bass. I'm fairly happy when I get a tone I like from what ever guitar I'm using. It might be a different tone from another guitar, but that's OK. I play the Charvel more than my hand made set neck Tele, just because it has a certain vibe I like. I've had the stock Jackson pickups, EMG's, Gibson Dirty Fingers, a DiMarzio Super Distortion, etc. And each time it still has the same basic tone.
So maybe try some non Fender guitars, and you might have better luck. You never know!
