Originally posted by Mike Sulzer
View Post
As for noise pickup, I built my circuit on a piece of vectorboard mounted in a diecast metal box, with BNC inputs and outputs, and binding posts for the pickup under test, and had no problems. The dark side of sensitivity is sensitivity -- full shielding is required.
I also used OP27 opamps, versus generic ~741s, and had no problem making measurements at 20 KHz (limit of interest, not OP27 capability). The 741s didn't work quite well enough, as I recall, but I don't recall exactly what the problem was, although limited open-loop bandwidth is a likely contender.
http://www.analog.com/en/other/milit...s/product.html
This effort started in May 2003, when I was first trying figure out how to accurately measure pickups. The use of the Maxwell Impedance Bridge and discovery that the Extech LCR meter was suitable arose from this same effort.
