Don't we still need a very uniform field to be able to equalize the two coil's outputs? I suppose we could measure them one at a time in the exact same spot.. Is a 50-60 Hz sine wave the ideal frequency and wave form to test shielding in a guitar? I'd think white noise or pink noise would give us a better idea of what our shielding is capable of at the various frequencies we need to worry about.
As far as designing a helmholtz coil it should be a simple matter of ohms law once you look up the resistance per foot of the wire you want to use. You just need to decide how much power/heat you can dissipate to air.
