I'm making some neodymium bass pickups, and the magnets are cylindrical: 1/4" diameter, 1/5" long.
they're basically glued between 2 pieces of 1/8" plywood(it's actually thinner than that) . if I were to make a p-bass style pickup with 2 magnets per coil, how many wraps per coil do you think I should use? (42awg), how many wraps should I use for a "soap bar" bass pickup with the same specs?
I assume that since neodymium pickups are stronger, that they could use a smaller coil, and still retain good lows with the improved mids and highs.. how many wraps do you guys recommend?
