Bobbin and cover material??
http://coneyislandguitars.com
The stock pickups in an Epiphone Dot have a brass cover, and a brass baseplate. The DCR is reasonable for a PAF style pickup, but the sound of them isn't even close, with the highs being harsh and washed out, and the bass being too muddy and indistinct. It can't all be due to the wind, which makes me think the brass cover and baseplate are the major contributing factors.
I put a couple Seymour Duncan pickups I had in it (Alnico 2 Pro in neck and Pearly Gates in bridge), and while not perfect, I can definitly hear an improvement in the sound. Some unpotted pickups will be better, but these are a great improvement over the stock pickups. The major difference apart from the wind is the nickel baseplate and no cover.
Personally I'd never wind a pickup using metal bobbins, and I'd stay away from brass too because everything I've heard it in sounds bad.
Greg
