Originally posted by David Schwab
View Post
Humbucker magnet Idea
Originally posted by Donfunnici View PostHere is an idea for humbuckers.Instead of using a spacer to extend the magnet from one set of poles to the other why not use a bar magnet that is wide enough to contact both sets of poles without a spacer.Just a thought.J
Originally posted by Manlius View PostI do reckon that it pretty much already does what you are looking for. Perhpas a wider magnet with holes for the adjustable coil, so you can skip the spacer and have the magnet act like the spacer, but I am not sure of the soundness of this idea, nor the logistics....
You just want the magnet to touch the screws.
Leave a comment:
The keeper that the pole screws go thru on a slug/pole screw style of humbucker pickup.
Leave a comment:
When saying "spacer" do you reffer to the steel keeper bar or maybe the Dimarzio plastic holder thingy from the Air series of pickups?
Leave a comment:
Leave a comment:
Here is an idea for humbuckers.Instead of using a spacer to extend the magnet from one set of poles to the other why not use a bar magnet that is wide enough to contact both sets of poles without a spacer.Just a thought.JTags: None
Leave a comment:
